cam chain to gear drive conversion
Old 10-23-2012 | 08:41 PM
mjaw's Avatar
mjaw
Question cam chain to gear drive conversion
I plan on changing the cam chain to gear drive on my '04 Road King,88ci. I was gonna go with a S&S gear conversion and replace the cams also. I see that S&S has many kits to choose from. What kit and cams would be best to install? Are Andrews cams a good product? Thanks.
Old 10-23-2012 | 08:48 PM
soft 02's Avatar
soft 02
Andrews makes great products. Why not go to a hyd set up?
Old 10-23-2012 | 08:54 PM
SpiderPig's Avatar
SpiderPig
I was always with the understanding that Andrews ground the cams for S&S.
Old 10-23-2012 | 08:56 PM
soft 02's Avatar
soft 02
Prolly do. They grind them for Woods.
Old 10-23-2012 | 08:58 PM
QC's Avatar
QC
+1 on Andrews cams.
Old 10-23-2012 | 09:00 PM
mjaw's Avatar
mjaw
I heard that the gear drive was more durable than the hyd. set up. I only have 13kmis. on the bike. I bought it last year with 6k mis. I haven't checked the condition of the wear shoes yet. How many miles can you typically go before you have to replace them?
Old 10-23-2012 | 09:02 PM
Pumba11's Avatar
Pumba11
My Andrews 21 cams with the hydraulic tensioners have been fantastic in a 88" motor. Can't say enough good things. If you go gear drive make sure your crank is within specs. I'm sure someone will chime in on the specifics.
Old 10-23-2012 | 09:03 PM
soft 02's Avatar
soft 02
Here is a pic of my hyd shoe's at 90k. They are very reliable plus you get a better oil pump and no shimming set up like when you set up gears.
Old 10-23-2012 | 09:05 PM
soft 02's Avatar
soft 02
.003 is max and most builders prefer .002 or less. 07+ Hyd spec is .012
Old 10-23-2012 | 09:07 PM
soft 02's Avatar
soft 02
Until you upgrade your tensioners I would recommend you make a regular practice of cutting apart your oil filter every service. You will be looking for small pieces of orange plastic.
Quick Reply: cam chain to gear drive conversion
