cam chain to gear drive conversion
Old 10-23-2012 | 09:14 PM
mjaw's Avatar
mjaw
I think I will go with the hyd.set up with Andrews cams. Whats the typical cost of the conversion with the cams.
Old 10-23-2012 | 09:17 PM
soft 02's Avatar
soft 02
Good read. http://www.hotbikeweb.com/tech/0612_...t/viewall.html
http://www.andrewsproducts.com/
Old 10-23-2012 | 09:19 PM
soft 02's Avatar
soft 02
Are you mechanically inclined. Not that bad of a job.
Old 10-23-2012 | 09:24 PM
mjaw's Avatar
mjaw
Talking
Yep I could do the job myself. Thanks for the advice.
Old 10-23-2012 | 09:25 PM
vheflin's Avatar
vheflin
I plan on changing the cam chain to gear drive on my '04 Road King,88ci. I was gonna go with a S&S gear conversion and replace the cams also. I see that S&S has many kits to choose from. What kit and cams would be best to install? Are Andrews cams a good product? Thanks.
I installed a set of S&S 570G's in my 2004 fatboy and haven't had one problem. The piece of mind with the gear drive set up is nice. I'm not sure I understand the advantage of replacing the original set up with the hydraulic tensioner as there is still a shoe to wear out. Perhaps someone can school me on this one.
Old 10-23-2012 | 09:33 PM
soft 02's Avatar
soft 02
You get a better oil pump. You dont have to have a crank that is perfect. They are reliable. You have less rotating mass. If not set up/shimmed right gears make noise. A easier job for a DIY person. Hyd set up is cheeper. Nothing wrong with gears. They served a purpose when the spring type tensioners came out but I prefer hyd set up. Do some research and decide for yourself. Tons of info out there.
Old 10-23-2012 | 09:47 PM
QC's Avatar
QC
Did it myself this past spring. With purchase of bearing removal tools from Heartland, I was in at $900. Took about 5 hours. I'm mechanically inclined and took my time. I understand now that Autozone and maybe another auto parts store may have tools that you can rent to get the old bearings out and new in. Might be worth looking into.
Old 10-23-2012 | 09:59 PM
soft 02's Avatar
soft 02
Here is a great thread with tons of pics and step by steps.
https://www.hdforums.com/forum/touri...-write-up.html
Old 10-24-2012 | 05:17 AM
Rev Heat's Avatar
Rev Heat
I put S&S gear drive cams in my '04 EG and loved them. I put them in at 19K and it had 77K trouble free miles when I let it go. I don't remember the number but it was the cams designed for touring bikes with mostly two up riding.
The most noticeable difference was in 5th gear when you wanted to pass a car or get on down the road. Really helped a stock 88.
Old 10-24-2012 | 09:55 AM
roadglider1's Avatar
roadglider1
I had the S&S gear drive kit with Andrew 26g cams in my 04 Roadglide. Bike ran great
with lots of torque from 1800-4000 rpms.
Quick Reply: cam chain to gear drive conversion
