did the garage opener to the headlight,, just courious,, i run with the high beams quit a bit,, so what will this do to the circut board???? i know it will only open the door when in range, but with the high beams on all the way home sometimes means 12v to the board all the time i am using the high beams,, so mabe wiring to the brake light would be better???? any body had any problems with the board wired to the high beams,,?????
I run the high beams of the time and the only problem I have had to date is when the bike is started, sometimes the door will close. Not a real problem unless you are backing the bike out at the same time. Only took once to get used to it. I found that the door is rather hard on the head!!!
I've had the door opener on my 06RG for 6 years now and no problem with it. When I added the H-D driving lights the operation of the door opener would only work if the driving lights were on. Still can't figure that one out.
