Help! What is this and why does oil leak from here?
Old 10-17-2012 | 04:03 AM
Keithhu's Avatar
Keithhu
I bet its a gasket for the oil cooler. Mine was replaced under warranty, apparently its not uncommon according to a dealer in Mankato, MN. Once fixed, no issues.
Old 10-17-2012 | 04:43 AM
EnglishAdam's Avatar
EnglishAdam
Originally Posted by mkguitar
translation to "American English" : Locktite ( Brand) or medium strength thread locker
mike
Erm, kind of.
The Hermatite that my fellow UK homie references is a silicon sealer for spreading in gaskets so it isn't that great on threads.
I'd go with the Green Loctite 290 for this as it wicks through the threads and will also fill slightly porous areas.
Good application chart here http://www.henkelna.com/us/content_d...king_Guide.pdf
Old 10-17-2012 | 06:12 AM
Nicky Pass's Avatar
Nicky Pass
The bike is a 2012 with the stock oil cooler. The 1000 mile service was done....the pic is from the front where the oil filter meets the oild cooler. I've searched and read that it could be the gasket, the bolt that holds the adapter plate....either way, a bike that had the 1k servoce should not have any leaks! I have to call the dealer today....I hope its a simple fix.
Old 10-17-2012 | 07:49 AM
JohnnyC's Avatar
JohnnyC
Because of the position of the oil filter, oil is going to get on the frame, and in-between during a filter change.
I'd degrease it (careful what you use) and wash the whole area. You could be seeing oil that was in areas you couldn't simply wipe. Heat the bike by riding it and the oil will thin and seep onto other areas.
Hope it's that simple.
Old 10-17-2012 | 10:26 AM
Nicky Pass's Avatar
Nicky Pass
I hope so too....it's going to the dealer in an hour!
HDLO
10-31-2022 11:50 AM
Phlipper
Engine Mechanical Topics
09-07-2015 12:55 PM
RonT
05-21-2012 12:06 PM
skyking
06-12-2010 05:11 PM
daharleyrdr
01-11-2009 07:41 AM
Quick Reply: Help! What is this and why does oil leak from here?
