Gps?
MAny of the GARMIN GPS units will allow you to map out a route and down load it via USB cable to the unit. Harley has a trip planner web site that that works pretty good. http://rideplanner.harley-davidson.c...idePlanner.jsp The Garmin 660 comes with software to allow you to do this also as I think several other models do also.
This is my preferred method of using the GPS....I like to travel those back roads and stay off the interstates. I will plan a route for a 4-5 day trip and never have to look at a map.
I sometimes use the java applet "GMapToGPX" found here:
http://www.elsewhere.org/journal/gmaptogpx/
Decide of a route using Google Map then you call this routine from your FAVORITES menu and the route coordinates appear visible in text mode. Copy, paste in a text editor, save_as '.gpx' then you download to the Garmin.
You will follow the route (line) but will not be informed to change direction.
