Removed trunk. Which backrest to use?
remove trunk which back rest to use
hi .saw 1 membre with flhtp. who put the detachable back rest on ..with u-clamps. bolts on the back of rack. belive you have to drill hole in side plate .have same probleme with my 11 .may try back rest from. softail deuce..this thing bolts to fender. but will try to bolts to my low profile seat. not sure about size height will see this winter .assume you unbolts your tour pack from the rack.mrfuji
