It is only a torx bit, no different then carrying a screw driver or wrench for that matter.....if they're cracking the lids, nothing will stop em, I believe its a matter of, if its a pain in their *** they'll flock off and go for something easier.
Well - almost, except it's a Torx with a security pin in the middle thus requiring as special tool. Sure, you can buy said tool, but is the average thief really likely to have one?
They're as easy to find as your first click on google, don't leave home without one ....
Sure - I have a full set. Not sure what your point is. There's a row of baggers parked at the Best Western for the night. You're a crook and you figure you can pop 3 or 4 sets. Which ones are you going to mess with? The ones with security torx bolts?! Probably not.
I was always a little worried about the bags being held on with only a wire. I replaced the oem wires with the u-nuts and 1" bolts. In addition to the added security, I don't feel like I have to constantly check the bags to see if the bags are still attached on trips.
This is exactly what I did. I only did it to the rear mount on each bag.
You have conviced me that this is a cheap and easy method not just for deterrence but like Irish Joe said to replace the wire clip for better fastening and peace of mind. I am going to do this, however, it still seems that it would be just as easy for a thief to simply un-bolt the brackets from the frame. I suppose nothing can really stop a determined thief (unless it be my 357 up his nose should I catch him) but it may be enough to have him pass me up for something easier. Thanks for posting Paulhog.
