Screwed up today
Screwed up today
I am embarrassed to admit that today after servicing the tranny on my 2012 SG I noticed that the gear lube level was above the full mark on the tranny dipstick.
So I took a syringe and some silicone tubing with a small brass tube extension to try and suck out some tranny gear lube.
Well as you you no doubt guessed the silicone tubing with the brass tube fitting fell off the syringe and fell into the tranny.
I drained the tranny and tried to look down the fill hole but I can't see anything.
I also tried a small hemostat into the fill hole with the hope of being able to get a hold of the tubing with no luck.
So my question, what is the least hassle way to get into the tranny to remove this tubing?
Would removing the oil pan give me access to the area I need to get to?
Thanks in advance.
Boy do i feel stupid.
Lesson learned.
Thanks in advance.
Lesson learned.
I can't see the tubing through the fill hole.
I'd say safety wire doubled over and folded into a hook and then some patience. Have used this trick to fish many things out of the about 7 feet of shaft and Main Rotor deice harness shaft of helicopters...torn packings are the worse and take about 30 min and 100 failed tries but you get it eventually. I'm sure you should be able to get it fairly easily
That sucks. Don't feel bad, we all mess up sometimes. I just went and did some experimenting on my 11 SG. I have enough clearance on mine to get an allen wrench into all the bolts on my tranny cover. Removing the heat shield gives me full access to bolts on the oval part and I can get to the two larger ones from underneath. Hopefully you have a lift. I'm thinking if fishing it don't work you gotta drain it and pull the side cover. Its a toss up as to whether or not you will have enough clearance to remove the bottom two bolts with the allen in the bolt. I had about 1/4" clearance between the back of the wrench and the exhaust. It just depends when they get finger loose. If it were me, I would sacrifice an allen wrench to the motorcycle gods and break out the grinder and shorten it up by 1/2" or so so I would definitely have enough clearance before starting. Don't forget to grab a new gasket. Good luck!
