Switch from Dual to Single Front rotors?
Is it necessary when switching from Dual to Single front brake rotors to upgrade to a 13 inch rotor and 6 piston caliper? Or can I simply remove the right side caliper and rotor? What does this process entail and does having ABS matter in doing this?
I went to single Hawg Halters 6 piston caliper with stock rotor on my 04 FLHTC and it stops very good.I can honestly say I didnt notice a loss in stopping. The 6 piston caliper has almost twice the pad area of the stock caliper.I notice my rotor wears much faster ,even with Lyndall Z pads.
Yes, there will be many to berate you. From my personal experience, RGC with single 13" rotor and six piston pm caliper. There is a difference in the feel of the setup...it is definitely not better than two brembos, but it is not worse either. I ride my bike the same as I did before I changed it, I do not naby it at all. No, I would not take a rotor off my zx-10r track bike, as a matter of fact I would add a third rotor if possible. But I dont barrel down road atl back straight at 180 endoing into 10a on my harley. Do it! And the abs still works
