SE Air Breather
SE Air Breather Question
Hey folks,
Did a bit of homework on this question and am pretty sure that I know the answer but thought I would double check with you folks.
I have 2011 FLHX and am looking to change from the stock air breather. I have a friend you has P/N 29478-05A which says it will fit an 02-07 touring. I then went online and checked the new air breather and it says 08 touring and up. Was there a change made from the 07 to the 08 which would not allow you to use the older air cleaner? I suspect that there was a change and that is why you cannot use it.
Thanks in advance for your help,
Kevin
Kevin
