headlight just shut off
OK, so headed home after dinner with my wife on a dark twisty country road with partial clouds, no street lights and about a half moon!
I always have my running lights on so people can see me easier and when I switched from low beam to high beam the whole headlight shut off for a split second. I thought, that was odd, then about a mile down the road, NO headlight at all! I'm grabbing brakes and trying to see where the hell I am, switching from high to low, nothing, switched off the running lights nothing! I get stopped and sit for a couple of seconds while my heart starts again and it comes back on. I try all the switches and it all works. OK, head out again, very cautiously, and NO headlight again. I'm almost stopped and it comes back on, I don't touch anything and it stays on until we get home.
Sitting in the garage I switch everything on and off and cannot get it to do the same thing. I know the dealership will not fix it if they cannot duplicate the problem. My bad for being long but I did a search and nothing popped.
Anyone who has had this experience please let me know so I can have this rectified ASAP! Thank you
OK, I'll start by asking what year and how many miles on the bike?
Check the connectors and fuse for any signs of corrosion, moisture loose or broken wires. Also check the switches, do they feel right (smooth click between positions) or do they feel sloppy or binding. It won't hurt to spray a little contact cleaner in the switches and connectors either.
The bike is a completely stock 2011 with just under 17000 miles. The switches feel fine, solid click into place and I should clarify, the headlight and running lights were out. I know the running lights go out on high but when I switched back to low beam the running lights would not come on either! I was clicking all the switches and nothing.
I have the extended warranty but I was hoping to pinpoint a problem because I'm not sure how far the dealership will look to find a problem that cannot be duplicated.
I will look over the connectors and wires just to see and thank you for suggestions.
