squeaking in primary
Old 09-17-2012 | 04:39 PM
Bens05FLHPI's Avatar
Bens05FLHPI
Default squeaking in primary
My 05 road king has 20,000 miles and there is a squeak coming from the primary. For lack of a better explanation it goes. Speak........squeak........squeak. Any speed. Doesn't matter if clutch in or out.
Old 09-18-2012 | 06:43 AM
Bens05FLHPI
Also the faster you go the faster it goes and it doesn't do it under 10-15mph
Old 09-18-2012 | 07:22 AM
valvestem's Avatar
valvestem
I am guessing it is your final drive belt squeaking.
Old 09-18-2012 | 07:39 AM
JohnnyC's Avatar
JohnnyC
Sounds to me like your primary chain may be too tight. Do you have an aftermarket self adjusting chain tightening?
Might even be the compensator is worn, or loose.
If you can get a mechanic's stethoscope you may be able to pin it down by the loudest location the sound is coming from. Although the whole motor resonates sounds that may be coming from a location farther away.
Old 09-18-2012 | 10:48 PM
dougbk's Avatar
dougbk
My money is on the final drive belt, if it does it while moving.
Old 09-19-2012 | 05:52 AM
cochon's Avatar
cochon
It's probably the final drive belt. They tend to squeak when the rear tire is misaligned.
Old 09-19-2012 | 07:56 AM
Bens05FLHPI
Ok. thanks for the input. I'm gonna look into it today. I just started like a mounth ago but then went away after a day or two and now is back and started like a week ago. I looked at the drive belt when it started again but I didn't see any sign of rubbing but I'll check it all again. Thanks everyone.
Old 09-19-2012 | 09:12 AM
MNPGRider's Avatar
MNPGRider
Before you do anything else, spray your rubber muffler mounts under your saddlebags with silicone spray to eliminate the possibility of that troublesome spot. If they are dry, the squeak they make will travel up your exhaust and you'll swear it's coming from the engine.
Old 09-19-2012 | 09:24 AM
Retrop's Avatar
Retrop
Originally Posted by MNPGRider
Before you do anything else, spray your rubber muffler mounts under your saddlebags with silicone spray to elimate the possibility of that troublesome spot. If they are dry, the squeak they make will travel up your exhaust and you'll swear it's coming from the engine.
That would be the first place I would look at too.
Old 09-19-2012 | 03:32 PM
Bens05FLHPI
I have a 2into1 exhaust out the right side and the squeak is coming from the left side.
Damascus
02-21-2012 04:29 PM
cecharles
10-27-2010 10:55 AM
fotoflojoe
09-05-2007 12:04 PM
turn55
09-25-2006 12:48 PM
HDF Tech
06-25-2005 11:31 AM
Quick Reply: squeaking in primary
