Fork oil change 2013 ultra limited
yeah, but the manual has you remove the forks and take them apart. just to change the oil, not necessary.
to the op, can't definitively answer your question, but i'm gonna go with same procedure as for the 07....
Me too
I also tried the SE Heavy and right after, rode on a dirt road with washboard finish. I could hardly keep it above 5-7mph and everyone in the group was passing me. Changed to Bel Ray 10 wt and like it.
On the 09 UC, it says to remove the forks and tip upside down etc, but if you remove the screw at the bottom of each fork tube, and work the forks, the oil will come out. I left mine over night to let it all drain down. Removed the inner fairing and unscrewed the fork tube cap, and using a long funnel, measured out the exact amount recommended and put everything back together. GTG
