1st time for Seafoam
Far from it. Use it every tank of fuel in my boat...mostly becaus it sits alot...and a few times a year in the HD...also use it in the diesel truck and tractor a few times a year to clean the injectors....diesel and gas uses the same Sea Foam
It is on sale at o'reilly auto parts for $6.99 a can so I normally buy about 4, although it is cheaper to buy it by the gallon.
I have used SeaFoam for almost 8 years. First was a Kawi 440, which was neglected with 50k miles, carbs that were so bad, it did not have a stable idle. After taking it down to a gallon of gas,and a bottle of seafoam....took on a 25 mile ride....presto, no more idle problems. I use it on every gas powered vehicle I have, carbs and fuel injection. Works great to clean varnish buildup and other deposits from fuel. Also have used to clean up oil systems that have neglected. Two thumbs up.
Well,
Found this SeaFoam (SF) at O'Reily auto parts for $6.99 a can. Bought two cans,and threw 3/4 pint in my RK went and filled up non corn premium.
Had some ping and after reading about SF on the forum of late, thought I'd give it a shot to see if it would help maybe stop some ping, and clean injectors, and stuff.
After running 50 miles and running it sorta hard, had it to 90 just blasting through the gears from a stop on some nice back roads with zero traffic to blow the gunk out.
I think the SF helps, bike seems more responsive, and not as much ping. It's only low 80 temps today, but pulling away from a stop, the bike seemed to have a wee bit more umph. Idle sounds better, smoother.
I will be using this more often, in the fuel. Too bad that I waited so long to try this stuff.
I was having some major problems when my '07 FXSTC began bucking like it was fuel starved when applying throttle, regardless of speed, gear or RPMs. I first noticed it when I was low on fuel, really low, so I attributed it to water in the tank and dumped in some STP injector cleaner/water remover with my next tank full and hoped that would be the end of it.
That didn't help at all, so I searched this forum and found about dozen other things to check, battery, charging system, intake leaks, CPS, plugs, codes, etc. but all came up negative for problems. As I burned through that tank of gas the problem worsened and I watched my mpg plummet in the process, so with about a 1/2 a gallon left in the tank I drained the rest, trailered it to a nearby Sunoco (the only station around me that sells 91) filled the tank and tried the STP stuff again. Still no improvement so I took it to my HD stealer who gladly took my $100 to tell me they couldn't find the problem either, but just to make me feel like I was getting something for my money they downloaded the stock MAP (I haven't made any mods other than cosmetic) which they said HD released an update to, so it might help. I didn't get a mile down the road when the bucking started again. And for the first time, back fired during a minor decel coming into a corner.
I'm was getting kind of anxious because I was on my way to spend a weekend in Deal's Gap for a "Tail of the Dragon" run that I had organized with some friends, and now wasn't sure my bike was up to the task. I came back to this and several other forums searching for "gas starved" reading the threads that got a hit and Sea Foam was mentioned in every one as the product that seemed to work when all else failed.
So the night before my trip I emptied my tank (again) and bought a pint of Sea Foam. I was trailering my bike down, so I left the tank empty hoping to find some ethanol free gas somewhere along the 700 mile drive to the Smokies, but my go-to internet site for finding corn free gas stations showed I'd have to go pretty far off route and since I was pressed for time. I ended up filling the bike with 93 at a BP station with "up to" 10% corn squeezin's, so I added half a pint of Sea Foam per the instructions (16 oz / 8-25 gallons) and hoped for the best when we went to slay the dragon.
For the first few miles heading toward the Tail, I could feel a noticeable improvement and I was getting optimistic, but just before entering the Tail from the NC side, it began to get worse, and needless to say the ride wasn't as enjoyable as I'd hoped. Fighting dragons with a dull sword is not fun at all.
We rode the Tail and around TN for a while before heading back to camp via the Cherohala Skyway. I filled up gain and added the other half a pint of Sea Foam. And from that moment on I didn't have a single problem. That was two weeks ago, and since then I've put about 500 miles on the bike and I'm back up to about 50 mpg after getting about 40 when the problem started.
Epilogue: I can say with 99.9% certainty that Sea Foam was the cure for whatever the problem was, whether it was bad gas, fouled injectors, water or whatever, it worked when the STP injector cleaner didn't. Since then I've put it in my Jeep Wrangler and '98 Subaru 2.5i too and have been getting better mpg and noticeably better acceleration with no loss of power when climbing steep upgrades at highway speeds. Now I keep a few bottles in my garage and pour some in all my vehicles every 4 or 5 fill-ups.
Sta-Bil is the additive I use for my RV and bike for winter storage. Supposedly keeps the ethanol from absorbing water causing corrosion inside your tank and fuel line. No miracle cure stories like I had with Sea Foam, but my RV sits outside under cover during the winter and a $10 bottle of Sta-Bil is a hell of a lot cheaper than the cost of repairing the damage a rusty tank can do.
ETA: You don't have to go a parts store to get Sea Foam. Target and Walmart sell it too, so you can pick up a few cans while shopping for clothes, toilet paper and/or ammo.
