Shift lever / shifter shaft rattle.
If its the shaft that fits thru the boss on the primary... Remove both outside shift levers , push the shaft back & apply grease to the shaft as best you can. Before you replace both levers get a 1/2" ID dia black nitrite type rubber o-ring, put it on the shaft then put the levers back on. The inside lever will need to be slightly compressed against the o-ring to get the bolt in. The outside lever goes on w/ no issues. This takes out most of the fitment slop & greatly reduces the rattle. Worked on my 07 SG.
I have been told (no personal verification) that the older machines came from the factory with that grease fitting already installed. Others have installed wave washers. Having some slop in the lever/shaft connection on the transmission seems very common also.
Yes, this is true, I have grease fittings on my 99 EG, one on the shift lever that goes thru the primary and one on my rear brake lever, I grease them a couple times a month.
Fureek
11
05-16-2019 12:45 AM
Frank the Real Biker
2014-2023 Touring Models
22
04-04-2016 01:57 PM
Road Star
05-10-2014 09:52 AM
