Brake light problem
Brake light problem
I haven't really gotten to ride the bike much since having it dyno tuned after Christmas so I thought I would ride it home from the shop today and to work in the morning. When I turned the shop lights off the rear lights were bright and I was thinking damn they are bright. It didn't dawn on me until I started down the road that maybe the brake lights were stuck on so I checked and sure enough they are. I thought maybe the run/brake/turn controller may have gone bad so I pulled the seat and unplugged it and plugged the connecter back the way it was stock and still the brakes lights are on. Has anybody else experianced this problem before? If so what was the soloution besides taking it to the stealer who I am sure will sayI did something to void the warrenty on the part somehow..LOL The bike is a 06 FLHXi with a little over 5k on it. Thanks in advance for any help.
RE: Brake light problem
Generally speakin', thar's jest two thangs that'll do it - the front brake an' rear brake. Check ta make sure that both are returnin' fully to their "full release position". Then check fer adjustment on 'em - usually, you'll find it's the microswitch on the rear brake that needs adjustment - just trace the circuit ta find the switch, then look for the adjustment.
my wifes bike did that it was the front brake micro switch was not getting pushed enough by the brake lever.Ihad put new chrome levers on so i thought that was it.
Now my question is there something to adjust?
I put a piece of 3m stick tape on the brake lever tabto help push micro switch it works fine now.
ORIGINAL: DaveUC
