No running Lights...
If bike is lowered, rear tire may have chewed up the wiring inside the fender.
the real cure is to get to someone who knows basic electricity and can trace the wiring from the tail light socket back to the fuse.
and check the bulbs too.
pt 2.
You should be doing a walk around pre-ride check.
One foggy night I just made out a station wagon with no tail lights---- moments later a big ol' truck rolled right over that car...
mike
pt 2.
mike
If you're looking for the turn signal lights to be functioning as running lights, they don't come that way from the factory. They are a single filament (1156) bulb. The fronts works as running lights/turn signals. The rears are signals only.
Harris
Denver, CO
www.youtube.com/conedown
Harris
Denver, CO
I just posted this issue I was having on my ultra. I changed a burnt fuse, put the new one in and all my running lights came on. Started it up and off they went again. Off to the shop to run down a short. Forum members started me with the fuse. My brakes and turn signals are on a different fuse than the running lights.
depends on year/model. for example, the last couple years, the street glides come from factory with just the two lights that flank the license plate - they are running/brake/turn.
To the OP - change out the bulbs first. always start with the simplest/cheapest.
I'm not the OP, but that advice only works for other folks. In my case it is NEVER the simplest or cheapest, I may as well go directly to the obscure and expensive solution.
