Finally pulled the trigger and done some heads and high compression pistons, early in the spring I done the woods 555 cams. Now have the SE CNC ported heads, high compression pistons. Dropped the PCV for the SE pro tuner, got 106 HP and 118 TQ.... I was hoping for 110 HP, the mechanic at the dealership told me if I done the 58mm throttle body and new injectors I would see those numbers. And then said unless I was just after an impressive dyno sheet to save my money as that would be a top end high RPM number. So I will leave it as is for the time being. It was at 94 HP and 110 TQ before the head work. So overall I am pleased with it.
