How To Change Brake Pads?
Old 09-09-2012, 07:26 PM
Dans03RKC's Avatar
Dans03RKC
Dans03RKC is offline
My fear with brake fluid is that stuff takes paint off faster then paint stripper. Could be a disaster if it spills.....
Old 09-09-2012, 07:43 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
Don't spill it.
Old 09-09-2012, 08:04 PM
T_Dogg80's Avatar
T_Dogg80
T_Dogg80 is offline
The service manual states to place a wide, thin blade putty knife to push the pistons back in. Doesn't mention to take the brake reservoir cover off.
Old 09-09-2012, 08:13 PM
stuart1270's Avatar
stuart1270
stuart1270 is offline
Originally Posted by dawg
I change my fluid every 2 years.
I guess some people don't read the maintenance schedule. You are supposed to flush every two years.
Old 09-09-2012, 08:17 PM
stuart1270's Avatar
stuart1270
If some topped of while the pads were low it is possible to overflow the master cylinder. better to remove the cover and remove a little fluid then compress pistons replace pads then press brake lever to seat pads and top off if necessary
Old 09-09-2012, 08:31 PM
Pelonz's Avatar
Pelonz
Pelonz is offline
I use thin wooden shims (the kind you would square a door/frame with), one from each side of the pad, to push the pistons back. Works like a charm and no marks on the rotor. I also remove the master cylinder cap.
Old 09-09-2012, 10:56 PM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is offline
Received 1,686 Likes on 704 Posts
Put some clear tubing on the bleeder nipple, crack it loose, and let the dirty fluid go that way instead of back into the master cylinder. Leave the cover on.
Old 09-09-2012, 11:40 PM
sifularson's Avatar
sifularson
sifularson is offline
I started using these several years ago and they are the best. Make bleeding or flushing (changing) the fluid a simple task. Be sure to buy the hose and bag with the bleeders you need.
http://www.speedbleeder.com
also on EBAY:
http://www.ebay.com/itm/Harley-David...item5ae9235f90
Old 09-10-2012, 04:15 PM
Wally's Avatar
Wally
Wally is offline
Originally Posted by sl954
Do not use any petroleum products on any brake components ever.
I think he meant he cleaned the outside of the pistons before pushing them back into their bores.
Yes, clean the outside of the pistons with brake cleaner, and lubricate the seals with oil applied with a q-tip.
Also clean the pins and lube them with grease. White lithium works well.
Cullmanco
12-17-2018 06:16 AM
harleyrider4300
03-30-2018 10:16 AM
Sandcrab
07-29-2013 02:34 PM
Krazyshark
Ironhead
08-31-2012 10:13 PM
DECON BLUE
15
11-26-2007 11:50 AM
Quick Reply: How To Change Brake Pads?
