Replacing Brake Pads
I am just wondering.
I have changed hundreds of sets of automotive brake pads and its a simple process of taking the cap off the reservoir, pressing the pistons back up into the calipers, and re-install everything.
On my FLH should I take the cap off the reservoir and risk getting fluid spillage or just slowly push the pistons back and go for it?
Thanks in advance.
Thanks in advance.
You can go to pharmacy and get a small syphon tube similar to eye dropper. First remove some fluid from master cylinder and do the brakes as usual. refill master cylinder. Bleeding is not necessary but I would recommend it to flush out the old brake fluid as it calls for in the manual every 2 years.
Received 49,910 Likes
It's recommended that you remove the master cylinder cover and remove some of the fluid .... Do you know if there has been fluid added to the system over time? ... If so there could/would be more fluid than the master reservoir could handle.
Wouldn't it be easier and less messy to replace the pads without opening the brake lines? That's what I did with mine, just take a large flat screwdriver and push the pistons back into the caliper before removing the old pads.
Once the brakes are back on then put a drain line on the bleeder and change the fluid. No mess no fuss.
