Custom dynamics install help
Old 09-02-2012 | 02:38 PM
captainmorgan71's Avatar
captainmorgan71
Default Custom dynamics install help
Did the search gig but nothing to answer simple...
2012 flhx
Installing led front and rear and have the cd 6 pin load equalizer... Simple enough.
Also purchase 8 inch custom dynamics plasma rods to install. Want some more rear lighting.
I want to run the plasma rods as brake and turn only. Can I do this? Or does it have to be run,turn,brake?
Also, do I need anything special to make this work. Cd website is confusing on what I need to make the rods only brake and turn. Can't tell what other parts are needed if any. HD dealer I bought from today had no idea.
Let me know
Old 09-02-2012 | 03:17 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
You might want to consider calling CD? Their customer service is pretty helpful.
They should be able to walk you through with your project.
Good Luck and Ride Safe,
YELLOWBIRD
Old 09-03-2012 | 07:49 AM
NELS's Avatar
NELS
Should be no problem, just use a test light at the connector under the seat finding which wire controls left signal and brake and connect into it and do the same for the right side.
Old 09-03-2012 | 07:54 AM
Chunker's Avatar
Chunker
As stated by the 1st responder, call CD. Their techs know their stuff, know what is compatible and will guide you to CORRECT installation. Or you could use the advice from someone on the forum who still thinks everything in the owners manual is gospel.
Old 09-03-2012 | 08:07 AM
Iceman24's Avatar
Iceman24
Don't know if this will help b/c my 09 FLHX wires a tad different than your 12, but I'd say all you need to do is cut/cap/don't conect the "run" wire & then they wouldn't illuminate for this option. Mine was the "orange" wire.
https://www.hdforums.com/forum/touri...-part-1-a.html
14StreetG_cruiser
Electrical/Lighting/Alarm
03-27-2017 11:06 AM
sevitz5
01-09-2017 03:12 PM
maverick2076
2014-2023 Touring Models
11-03-2014 07:55 PM
MDStbob
09-25-2013 10:57 AM
Booda_do
03-18-2013 08:24 PM
Quick Reply: Custom dynamics install help
