Lowering two touring bikes - without stripping front end?
Old 09-02-2012 | 01:25 PM
trip59's Avatar
trip59
Default Lowering two touring bikes - without stripping front end?
Hi folks, I've searched but haven't really found what I was looking for.
98 FLHP and a 99 Ultra Classic.
Rears I'm going with Progressive 412, front I'm looking at Progressive drop ins.
Now, the question... can these be done with removing the caps, loosening the pinch bolts and sliding the front end down or out INTACT? Or is stripping the wheel, fender, brakes, etc. a must?
Thanks for the input.
Old 09-02-2012 | 01:43 PM
grbrown's Avatar
grbrown
Lightbulb
If you go to their website, Progressive publish instruction sheets for their products, so you can see what you are letting yourself in for!
Old 09-02-2012 | 02:04 PM
trip59's Avatar
trip59
I'll look again, the download instructions and vids don't go into detail about what CAN be done:
Per the instructions in a an authorized shop manual remove the forks from the motorcycle. This will entail removing the wheel, fender, and possibly several other items depending on the model - again, refer to an authorized shop manual for the removal of these components.
Old 09-02-2012 | 04:08 PM
Tee Bagger's Avatar
Tee Bagger
Yes, have to remove forks...very easy though. Then remove caps, remove springs, drop in new springs....done. I would change the fluid also...
Old 09-02-2012 | 06:41 PM
trip59's Avatar
trip59
Do you have to strip them down, or can they drop out as an assembly with the fender, axle, etc. still bolted together?
Old 09-02-2012 | 08:19 PM
RaceFace's Avatar
RaceFace
I tried to do it the second time because I didn't drop it down low enough and wanted to cut the spacers more. I couldn't pull it off. I determined it was more of a pain in the *** trying to keep it all together instead of pulling the whole damn thing apart again, so I sucked it up and did it again with the fork tubes removed. Your call man....
Old 09-02-2012 | 08:31 PM
EasternSP's Avatar
EasternSP
Veteran: Marine Corp
You're going to have to separate everything anyways, so just take the front end apart instead of trying to remove the frontend in one unit.
Old 09-02-2012 | 08:41 PM
FL-kruzen's Avatar
FL-kruzen
I don't think you can do it as an assemble. You have to get to the hex head screws that are located on the underside of the forks.
Old 09-03-2012 | 02:49 AM
grbrown's Avatar
grbrown
Exclamation
You obviously haven't taken a dresser front end apart before! All together that lot weighs a great deal, and simply manhandling a heavy awkward shape would be a challenge, let alone threading the fork legs back up through the trees. Have the good grace to accept that the only practical way to do what you want is to dismantle the lot! If you don't have one get yourself a factory service manual before you start work, as Progressive themselves recommend.
BK26_SLICK_SG
02-14-2014 12:25 PM
customsoftail200
11-16-2013 11:25 AM
9vapors
05-10-2011 02:29 PM
DGlide04
01-07-2010 08:13 PM
DGlide04
01-07-2010 07:38 PM
Quick Reply: Lowering two touring bikes - without stripping front end?
