Notices
How many miles on Fuel Moto 107 build?
Old 09-02-2012, 09:27 AM
Brick0044's Avatar
Brick0044
Brick0044 is offline
Default How many miles on Fuel Moto 107 build?
Just wondering how many miles people have put on a Fuel Moto 107 build. And if you have the level A or B heads. Pros and Cons? Thanks in advance.
Old 09-02-2012, 09:59 AM
RHillbilly's Avatar
RHillbilly
RHillbilly is offline
Have almost 4000 on mine installed it myself,stock heads,fuel moto download in pcv never been dynoed runs fine no issues other than doing speed limit
Old 09-02-2012, 10:20 AM
dan conner's Avatar
dan conner
dan conner is offline
great question--would like to see a bunch of these builds with 30 to 50 k on them before dropping my money on one.
Old 09-02-2012, 10:25 AM
Brick0044's Avatar
Brick0044
I'm thinking about doing it, but want to hear of some high mileage ones.
Old 09-02-2012, 10:38 AM
captainmorgan71's Avatar
captainmorgan71
captainmorgan71 is offline
I have about 4,000 miles on mine. Not a glitch or a hiccup. Jamie did all the work this winter. Stop thinking... Do it!
Old 09-02-2012, 10:49 AM
Brick0044's Avatar
Brick0044
You have the build I would go with. What kind of hp and torque numbers are you getting.
Old 09-02-2012, 11:13 AM
captainmorgan71
I will have to dig up dyno sheet.
I think like 116 hp and 121 tq
Non of the guys I ride with have been even close to me when we get on it.
Old 09-02-2012, 03:23 PM
Gearhead3's Avatar
Gearhead3
Gearhead3 is offline
I've put 14,xxx miles on mine, so far. Because of the cylinders being bored to the max, I've had some cooling issues. Even stock it's always run hot, and I'm running synthetic motor oil, a HD oil cooler and with a good tune. After doing the 107 the overheating problem was magnified. This Summer was especially rough with all the record highs being set in the Midwest. I wound up purchasing Jason's (Wards Parts Werks - Forced Convection System) cooling fans and my overheating problems have disappeared. The is the best 'peace of mind' addition I've made to the bike. In addition I had some starting issues when hot. High compression and a hot engine made the starter 'kickback' and make a terrible (embarassing) grinding noise. (especially on short stops, like at the pump) Leaving the cooling fans running while pumping gas has alleviated the vast majority of this problem as well.
Old 09-02-2012, 03:24 PM
Lyfer's Avatar
Lyfer
Lyfer is offline
I've got over 20k I imagine. (I can't remember for sure. I posted actual mileage in a thread a few days ago. Everything's good.) For some reason mileage has tanked recently. Just got back from Brookings, SD and was only getting about 33 mpg - down from 42 or so. Gotta go check plugs after it cools off and see if they tell me anything.
Old 09-02-2012, 04:08 PM
springer 03's Avatar
springer 03
springer 03 is offline
If you do it make sure to get compression releases. My stock starter went south after 3 months and my 1.4 kw starter is crapping out after 5 mos.
Quick Reply: How many miles on Fuel Moto 107 build?
