How many miles on Fuel Moto 107 build?
#32
Precision bored OEM cylinders ready to install with ring end gap set (core exchange, or send us your cylinders)
It doesn't say anywhere that a new set of cylinders are part of the deal.
#33
#34
Cool thread,
I have 4,000 on mine since assembly a month ago. My starter took a dump before it even broke in, even with compression releases...
I can't believe how fast the road king is now. It's definitely a better bang/buck vs trying to buy a cvo or anything close to new at the dealer
Jake
Jake
#35
I've put 14,xxx miles on mine, so far. Because of the cylinders being bored to the max, I've had some cooling issues. Even stock it's always run hot, and I'm running synthetic motor oil, a HD oil cooler and with a good tune. After doing the 107 the overheating problem was magnified. This Summer was especially rough with all the record highs being set in the Midwest. I wound up purchasing Jason's (Wards Parts Werks - Forced Convection System) cooling fans and my overheating problems have disappeared. The is the best 'peace of mind' addition I've made to the bike. In addition I had some starting issues when hot. High compression and a hot engine made the starter 'kickback' and make a terrible (embarassing) grinding noise. (especially on short stops, like at the pump) Leaving the cooling fans running while pumping gas has alleviated the vast majority of this problem as well.
