Stage 1 DIY? and looking for advice
Hello all,
I'm interested in a stage 1 kit for my 2005 Road King Police. Planning on doing this myself, as it seems a pretty straightforward job. (Hope I'm right...)
So far, I'm thinking slip-ons from Supertrapp (SE series), and Screaming Eagle or Arlen Ness air cleaner. (I'll take recommendations?)
My question is about the fuel management - I was originally thinking PCIII. But now I see there's a PCV retrofit that I can use from fuelmoto for my bike.
And, when exploring options at the HD dealer, they try to steer me away from Power Commanders, and say the way to go is the HD EFI Super Tuner - as it adjusts the ECM, and doesn't (as they put it) piggy back on the ECM. And they also say that dyno tuning is a requirement to get good results. True?
Anyone have any thoughts on this? I'd appreciate it. I'm new to this forum, and new to Harley Davidson, but I've been riding for 30+ years.
Sure you can do it! I got Screaming Eagle Air cleaner and V&H pipes, called Jamie at Fuelmoto told him what I had, he programed and sent me Power Commander. It was plug and ride. Only had to make one adjustment. Had popping on decel. Jamie had me make an adjustment on the "0" throttle position and it cured the problem. Saved alot of money to buy other goodies!
If you're thinking about going with a PC-V retrofit from Fuel Moto, be sure to give Jamie or Keith a call and let them know you've got a police bike. When I had a PC-V on my 07 Road King police, there was limited map support available for my bike. I don't exactly understand why the police bikes would have different maps than the civilian bikes, but it came up a number of times. When I built the 107 motor last winter, I emailed fuel moto for a new map, and was told that they couldn't help me with a map, let the autotune dial the bike in. Ultimately, I got rid of my power commander and went with a tts.
I never was really happy with how my bike ran with the power commander. It ran good, but got lousy mileage (around 30 mpg), and always smelled like gas when I shut it down. It ran better with a fuelpak than it did with the power commander.
When I redid my top end last winter, I installed a SERT, then upgraded it to tts. Even though the motor's significantly more ballsy now (107/10.8 compression/woods 8 cams) it gets better mileage (upper 30s) than when it was 103/se204/PCV.
Received 4,212 Likes
Yes, a Stage 1 install is pretty straight forward. The more difficult aspect is choosing the components to use.
I have been happy with the Power Commanders I have used on several bikes. Jamie at Fuelmoto is a great resource for them and maps.
On the Air Cleaner, you will get more performance out of an OUTLAW HiFlow 587 than most other Stage 1 A/C's, including the Big Sucker.
Here's a pic of just one of the many looks available with the OUTLAW-
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
To the OP.....welcome to the forum. There are many choices so my suggestion is get one that allows you to get into the different fuel and timing tables, throttle positions and RPM ranges. If the one you go with does not, your going to be dependent on everyone else instead of your abilities which is plenty.
As far as the exhaust, the SE fatshotz and some of the supertrapp models allows you to tune the pipes by adding or subtraction disks to get the desired sound and low or top end torque.
You PC needed a map modification, seems it was running way too fat. Lot's of us on here coulda helped with that easy enough. The SERT marries itself to the ECM. you cant take it with you...
Does the PCIII or PCV retrofit allow for dyno tuning, and getting into the fuel and timing tables, throttle positions and RPM ranges? Or do I need to go another route? Just to clarify, the TTS is the Harley Super Tuner, right? Which changes the actual ECM? And, can the TTS be a DIY install? Or just HD? Seems I have many questions...
I appreciate the help, and as I'm just getting into this, it's good to know there are folks on this forum willing to share their knowledge and experience.
You will get as many suggestions for a tuner as there are tuners out there on the market! They all have their fans in here and you will be rewarded by spending a little time reading recent threads. The choices range from those you need a dyno for, through others you can install maps on, to others you can learn to tune yourself.
IMHO there is no substitute for a dyno tune, as that is the only way to get the very best out of your bike. For that I suggest you chose your tuning shop and go with what they recommend. That way you will get the best out of them!
Another consideration is that if you have other tuning plans up your sleeve, wait until you can do that too, so you only pay once to get your bike set up.
Is it worth it?
I'll definitely give Fuelmoto a call. Seems like a great resource, and eventual source of parts, etc.
For those of you who have done a stage 1, I'm curious if you all feel it was worth it? The main symptoms I'm trying to resolve are that the bike runs rougher (I think leaner) when it warms up. Sounds and feels starved for fuel. Also, it doesn't run steady when moving/slow cruising in lower RPMs, in 2nd and 3rd especially. Fuel management while trying to hold a steady 20 or 25 mph around town seems a little grabby and uneven.
When I first bought my bike, I was glad it was bone stock, and now, just a few weeks in, I'm already thinking about modifying...
This could be a slippery slope...
