107 turning on abs light?
Old 08-30-2012 | 11:00 PM
av ultra's Avatar
av ultra
Default 107 turning on abs light?
On my last test drive I was rolling thru a intersection and when i crossed the paint it broke the tire loose, after that the abs light was on, when I came home I shut it off then pulled the codes and nothing on abs. My question is if you break your rear tire loose will it set the abs light on?
Old 08-30-2012 | 11:50 PM
Neal Smith's Avatar
Neal Smith
I don't Know about everyone else but mine does not do it.
Old 08-31-2012 | 07:34 AM
blue flht's Avatar
blue flht
Mine does not and I have had spun the rear a few times.
Old 08-31-2012 | 08:17 AM
psychocircus's Avatar
psychocircus
It shouldnt come on less theres an issue with abs system. If it stayed on something is wrong. Since it didnt come back on after shutting down and restart i think you may have a wire starting to break loose on the sensors...most probally the front, behind the chrome cover below headlight, the front sensor plug is there and turning the forks the leads coming off the top of the plug get pinched/ folded over both ways by the main harness. Start the scoot and do some quick full lock turns both ways. If the light comes on...theres yer problem.
Old 08-31-2012 | 09:03 AM
av ultra's Avatar
av ultra
going to try it.
pawpaw61
03-24-2019 08:23 AM
1fathog
03-22-2013 07:21 AM
Just Me
03-04-2012 08:02 PM
glide2005
01-17-2011 11:56 AM
ptl203
07-19-2010 07:40 PM
Quick Reply: 107 turning on abs light?
