Where do i get a socket for brake pad installation on a street glide front end?
Old 08-29-2012 | 01:39 PM
Jswerve's Avatar
Jswerve
Default Where do i get a socket for brake pad installation on a street glide front end?
Is it a 12 point socket?? Anyone know what size?
Old 08-29-2012 | 01:42 PM
dparker747's Avatar
dparker747
On my 09 Road Glide, it is a 10 mm 12 point socket. Can find them any place that sells tools (sears, harbor freight, lowes, home depot etc.)
Northbound Southerner's Avatar
It is just a 12 point 10MM if I remember right...
Old 08-29-2012 | 01:47 PM
Jswerve's Avatar
Jswerve
Thanks guys, of course the only 12 pt sockets I have are standard lol.
Old 08-29-2012 | 01:51 PM
Jackie Paper's Avatar
Jackie Paper
Actually, the 12 point in metric is not a common standard for most socket sets. However my offset box wrenches are. You check? Does take slightly longer that way? HA
Old 08-29-2012 | 01:52 PM
Punjabi Rider's Avatar
Punjabi Rider
Make sure socket or wrench is tight fit and all the way in and strike it with a hammer to get loose or it might slip and will be a problematic.
Old 08-29-2012 | 01:54 PM
Came standard with my 3/8 drive set...I just pulled the wheel on my bike last week...
Old 08-29-2012 | 02:12 PM
Jswerve's Avatar
Jswerve
I have a box end 10mm snap on wrench I can use
Old 08-29-2012 | 02:17 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Craftsman universal metric sockets - work on 12 pt, hex, square, rounded, etc. have never caused an issue. a set of metric is about $12.00 (without the ratchet)
Old 08-29-2012 | 02:22 PM
soos's Avatar
soos
Are you referring to the bolts that hold the caliper to the forks or the pin bolt that holds the pads themselves? If it is the pin bolt you will need a 1/4" 12 point socket or box wrench.
Quick Reply: Where do i get a socket for brake pad installation on a street glide front end?
