Exhaust Questions
Exhaust Questions
I have a 2010 FLHX with 2 in 1 Reinhart 3" slip on. I want to change this to 4"....
Should I keep 2 in 1 setup?
Should I go with 2 in 2 setup?
Should I go True Duals?
Not sure what to do here... I wanted to go True Duals but I don't like the pipe running through the middle of the bike creating more heat... I live in Florida.
Which way?
The pipe running underneath the bike produces minimal heat...and that's mainly why it's under there...you don't feel it!
The stock 2-1-2 setup is actually very efficient. You'll get the best results with good mufflers and a proper ECU map or whatever fuel managment you're running.
Good luck
Good luck
