Very light front braking, caliper pistons barely moving.
Old 08-24-2012, 07:58 AM
Very High Plain Drifter's Avatar
Very High Plain Drifter is offline
Sounds like a blockage somewhere along the line.
Old 08-24-2012, 07:55 PM
KiloGolf4's Avatar
KiloGolf4
KiloGolf4 is offline
Well, didn't think it would work but it appears the "tie the brake lever down overnight and tap the calipers with a mallet" made a significant change in travel.
I took it out for a ride this evening and the front brake is stopping a lot better. The lever starts to tighten up about 1/3 of the way and at 1/2 travel it is hard with good clamping power.
We'll see if it holds up though... Thanks! KG
Old 08-24-2012, 07:58 PM
KiloGolf4's Avatar
KiloGolf4
Originally Posted by EasternSP
Make sure you use the right DOT brake fluid in them. I don't have the book in front of me here but there is DOT 4 and DOT 5 and you're not supposed to mix them.
It calls for DOT5 on the cap of the master cylinder. Even though the problem appears to be fixed now, I still plan on flushing/filling both MCs with new fluid. Thanks! KG
ronnie41653
Wheels/Tires
03-11-2019 10:08 PM
that$pit
02-09-2015 01:19 PM
Krazy8s
05-15-2014 11:20 AM
lunyty1
03-03-2012 10:30 AM
chikenfat
11
11-02-2010 06:37 AM
Quick Reply: Very light front braking, caliper pistons barely moving.
