Another CAT Question
Jim,
the thing to watch out for is pinging- it'll sound like pebbles shaking in a coffee can.
It is most likely to happen when suddenly opening the throttle or when running up a grade ( and I think more likely given the weight of a tri-cycle)
if you experience this then you need to resolve it.
persistant pinging can burn a hole in the piston- momentary pinging will usually cause the ECM to retard ignition timing, which will reduce power
My 09 pinged from new - completely stock under certain conditions ( 2800~3200 rpms, up 6% grades) and i added nightrider.com xieds which solved that. I then was able to go stage 1 with no further tuning compensation.
SOME bikes run stage 1 with no tuning compensation, and as shown with my bike, some need help.
I would think that after dropping cash on the exhaust you would want to go to a high flow air cleaner--- until you do that you will not realize the performance potential of the exhaust.
Best bang for buck is the Ness big sucker with chrome backing plate- under $120 on ebay from easternpc
Mike
Mike
