Progressive fork springs in 97 Road King
Hi everybody,
I have a 1997 Road King FLHR which has the front fork air assisted suspension that Harley used in that years. As this suspension gives me a lot of troubles like air loosing, etc. I would like to eliminate this system replacing it with a non air assisted system that works well and without troubles.
I've been looking for new springs in the Progressive Suspension site and it seems that I can put the Progressive 11-1131 fork springs (stock height, I don't want to go lower) in my 97 Road King and I would like to know if this is true and if I would need to do any other work in the forks to install this springs. I know that I must plug the upper fork caps to avoid leaks but I would like to know if any other work should be done.
This are the springs: http://www.progressivesuspension.com...ngs/index.html
What do you think? Can this be done so? Am I missing something?
Hi everybody,
Thanks for your answer.
Finally I've done the job. I've installed the Progressive Springs, I've removed the front air lines and I'm very happy with the job done. I must say that is a great improvement and since now, I'll never have air leaks and I'll never have to fight with the air pump in the middle of a road trip.
For anyone who wants to do what I've done, I've put some pictures in my personal blog, where you can see it. I must say that as I'm from Spain, the blog is in Spanish, but I suppose that just looking at the pictures you'll understand the procedure.
As soon as I discover how to do it, I'll open a thread with the same pictures and will try to explain in English what I've done.
Here you can see how I've done it:
http://www.elcuelgamonos.com/?p=3786
If you have any questions about this, please let me know and I'll try to explain it better.
SixStringer
05-14-2016 06:24 AM
