Power commander problems
I have a 2000 RK with with stage 1 True duals and V&H slash cut mufflers. Over the weekend while on a trip the bike wouldnt start. We disconnected the powercommander and the bike fired right up and ran like a top. We finnish the weekend with no problems and had better fuel milage. Throttle response isnt as good as it was but can live with that. My question is, am I hurting anything by running without the PC III usb. My bike has the MM EFI. I dont want to buy another power commander. I was told I am safe and that the PC is for fine tuning and more power but just want to be sure. Thanks
I would just put an XIED and call it a day. Then only reason Im running a PC is because I needed the timing retarded or I still would still be running the VIED I had in it before and since you dont have 02 sensors thats where I'd go. I would see if the PC can be warrantied, did it come on the bike or did you buy it new?
If the CRANK POSITION SENSOR SIGNAL is not perfect the power commander will have issues and your bike may not start..It can be hit or miss to start.
The sensor itself might be OK but a small nick, cut or slightly loose/bad connection would cause a problem..
Check and recheck the sensor, from motor remove, clean , re-install same sensor then follow wire to connector near battery and open/clean and make sure it is tight and reattach with zip ties then remove connector at ECM and clean both sides, re-clean and re-install...then if everything is good test with power commander...highly likely that something is loose and signal is weak....and make sure to run bike with power commander or you are running lean...once in a while the sensor is bad but it is more rare so do not waste money until all above is checked because a new sensor will do nothing for a dirty ecm connection.
Ditto! You were running leaner while the PC was disconnected, thus the better gas mileage, but decrease in performance. The key is to keep these motors running as cool as possible since they are air cooled. More fuel equals slightly cooler temps and that will help protect the motor. You want to use a tuner to richen the fuel, but you can go too much which is also not good.
Stupid but what is a xied and vied. i bought the bike second hand with all this stuff on it. what are my options if i leave the pc disconnected? I'm not crazy about it and dont see much difference in power but the fuel milage is a lot better. with pc i was getting 30-35 and without I'm getting 45-48.
Do you have any popping on decel or down shifting? That is a big difference in MPGs. Like mentioned earlier, I would be worried about running too lean and heat issues. You can put new spark plugs in and after running a few hundred miles, pull them and see if they are looking like the bike is running lean or not. You can post pictures of the plugs on here to get an answer if your are unsure.
the power commander isn't whats killing milage ,its the map thats loaded in it,other options by cost,dealer download some like it it doesn't change much its designed for screaming eagle stuff.fuelpack v\h keeps it a secret on how to program it they don't tell what the switches do,power commander,only as good as the map u can have it dyno tuned only as good as the dyno operator,or run a canned map(get it from fuelmoto they have excelnt service and u can request milage map.there are many better tuners in higher price range but for a stg 1 i can't justify the money.
