Slip On Muffler Clamp Size?
The stock headers are 1 3/4". You'll need clamps that can fit over the slip ons that fit over 1 3/4". The clamps would need to expand to about 1 7/8" to 2" give or take.
Edit:
These should work:
http://www.ebay.com/itm/TWO-Stock-Ha...106fae&vxp=mtr
Edit:
These should work:
Just went through a pain in the *** experience. If you have double walled slip ons the stock clamps will NOT work. You will need 2" clamps. Measure before you buy the clamps. I have two stock clamps collecting dust because they would not fit. Needed to find special 2" clamps which are hard to find locally.
Thanks for the info. The clamps I have must expand when they get hot cause after a ride after the pipes cool down the right rear slip on is real loose. I tighten it back down and it's snug. Think new clamps will fix this? I have Samson Rolling Thunder Ovals. I'm not sure if they are double walled.
Does anyone know the part number for the rear hanger clamp and rubber mounts?
skos
05-10-2017 04:51 PM
ZeroFiveFour
06-03-2011 08:28 AM
