Just shut off???
Just shut off???
Bad day at work yesterday so got home and decided to ride to a local Bike Night to "ease the stress". Got 2 mile from home traveling on a local street at 45 MPH and the bike just shut down as if I hit the kill switch (actually thought I accidentally did). Coasted into someones driveway and, turned the ignition switch off and back on and the only thing I got was accessory power - no ignition, lights, etc. Tried the switch several times - nothing. Checked fuses - all good, by-passes the PC - no good, checked battery connections - nothing changed. Called AAA (that's the road hazard AAA) and 45 minutes later the tow truck showed up and took me back to the house. Since this just seemed to follow suit with the rest of the day I plugged the Battery Tender in and I called it quits for the day.
This morning, I was putting things back together to get the bike ready for the tow to the dealership and decided to just try the ignition switch. Damn thing turned right on. Turned it off and on 2 more times and started the bike right up. Shut it off... nothing again??? So now I'm leaning toward a bad ignition switch. Brought the battery to work and load tested it and it's fine. Heading to the delaership to pick up a new switch. Hopefully not a $100.00 parts swap???
Anyone have any thing like this that they could share their findings???
Mine does that some times when trying to start. I give it a "jiggle" and watch for the radio to turn on. After that flick the run switch watch for engine light to go out and start her up. It feels like it is in ignition but there must be a switch down in there that isn't getting what it wants. I little jiggle works every time. I have not had it shut down while rolling though.
I had a friends bike do that and the ignition switch was bad..I think it would get hot to the touch as well..
I do and I'm going to p-up a new one when I p-up the new ignition switch. Thanks for the reminder.
I would check the connector to the ignition switch housing. Pull the outer fairing and radio. You'll see the connector directly under your handlebars. Vibration may have caused it to loosen up. Since it is having some things light up, I'm willing to bet it is not fully seated. Should be maybe a 15 minute check.
