Notices
CVO rear fender
Old 08-16-2012, 06:34 PM
2011sedona's Avatar
2011sedona
2011sedona is offline
Default CVO rear fender
I have a 2011 street glide and planing on installing the CVO rear fender can anyone give me any details if I will need to buy a new wiring harness and/or anything else
Old 08-16-2012, 06:49 PM
JAKE 2544's Avatar
JAKE 2544
JAKE 2544 is offline
Do a search, there are plenty of threads on it including parts needed.
Old 08-16-2012, 08:16 PM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is offline
Old 08-16-2012, 08:48 PM
flhxkiller's Avatar
flhxkiller
flhxkiller is offline
if you buy the kit ($821 at LSHD) it comes with the harness required for install. It cost me $200 for paint and did it myself in less than an hour. You'll need to put it on a floor jack to have enough clearance to roll the fender off and install the new one. It's plug and play.
Old 08-31-2012, 12:43 PM
fightingmajor's Avatar
fightingmajor
fightingmajor is offline
Looking at the part, it fits 09 and newer touring bikes except the Road King Classic. Anyone know why that is?
Old 08-31-2012, 01:39 PM
Jswerve's Avatar
Jswerve
Jswerve is offline
Thanks!
Old 08-31-2012, 02:13 PM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
Because of the shape of the rear of the saddlebags. If you put hard bags on, you could probably do it.
Old 08-31-2012, 04:50 PM
fightingmajor
That's what I was hoping was the reason. Thanks.
Old 08-31-2012, 05:42 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Should be able to recoup some of your expense by selling the whole stock fender assembly. They are pulling between $400-$600 on ebay depending on the color. That would make final cost for the conversion pretty reasonable.
Old 08-31-2012, 06:23 PM
tincup64's Avatar
tincup64
tincup64 is offline
i've seen a couple that have the light at the bottom of the fender too (tri light?). how do you add this piece?
thx - tin
Quick Reply: CVO rear fender
