radio shack siren problem WTF!
RE: radio shack siren problem WTF!
i read in another forum where someone soldered 1/2 inch pieces of paper clips to the ends of the siren wires. this is what i did and it worked really well. the ends fit nice and tight into the factory plug. i drilled a hole just big enough in the end cap to stick the wires through, then sealed around the wires with some silicone.
ORIGINAL: tmaxx
hooked mine up today,easy install. It doesn't chirp when I turn it on or off, not sure if it is supposed to. When I bump the bike it chirps once and only alarms if I keep moving the bike. It does alarm if I try to turn the bike on. Thanks Rollntiger. Great tip. I never have used the alarm before this, because I thought it was useless with out sound.
ORIGINAL: devious56
If I may be so bold, where did you get your delphi connector? I like the thought of 'plug and play'.
Thanks,
Devious [sm=goodidea.gif]
Thanks,
Had the counter guy get out the connectors catolog and started looking.
Got real lucky when he had one on the shelf and didn't have to order it.
I will see if i got the reciept around here for the delphi part number.
PLEASE HELP This started out good, however after I check all connections and found they were good I proceeded to cut the plug off the wires and hooked up the siren. Decided to check it all out to see how it would work now before I button everything back up.[:@]...........Guess what...........I'll tell ya what.................. nothing. Dummy me forgot to disconnect the battery and it must have trip something and now motor won't start[sm=bangbang.gif]..........The radio plays and the lights work... but no start??????????? HELP what can I do......
ORIGINAL: 2buxleft
For future reference, never cut all the wires at once, clip them one wire at a time, as they will short accros your cutter when cutting.And once cut always keep wires seperated.
On the other side of bike, in the fuse block same row as the Light relay, there are two fuses, its the one furtherst away from the relay. (It is labeled "ignition" onthe fuse box lid with position)
Sound like a voice of experience, anyway after I got a coulpe shot of
'Turkey" down[sm=alcoholic.gif] I went back to determine what went wrong with this project and found that I DID indeed blow a dag-gone fuse. But hey ..................Now I can talk with a voice of experience[sm=wakeup.gif]Thanks guys, I knew I could count on some help here...............as usual
ORIGINAL: SteelCityScooter
Local Mom & Pops auto parts, been using them for years.
ORIGINAL: devious56
Thanks,
Thanks,
