Question about stock 103" MPG
2012 Ultra Limited stage 1 download, Reinhart slipons, se ac and Xieds. I ride 2 up 95% of the time. Cruisin 75-80 mph on highway, 6th gear, avg = 39 mpg. Cruising the back roads 55-65 mph, 6th gear, avg = 42 mpg. Pushing it on twistys, hills and really getting on and off the throttle, 2nd thru 5th gears, avg = 36 mpg.
My 07 if I'm by myself about 35 or less with few friends it behaves very well and gives me 40 plus according to Harley odometer which is about 5% incorrect and that is the case with almost all HD speedometers it will show 4 to 5 miles faster then actual speed when cruising at 75 or so.Took a trip to AZ on the bike it showed 556 miles took the same trip same route on my wife's Mercedes showed 531 miles go figure.
I hear 'ya! I grew up in 55MPH Seattle! The mid- south highways roll along at 75 minimum for the trucks and I can do 90 for extended periods when I feel like concentrating hard. :-)
Well my rubber mount when it was stage one got around 35mpg,fuel pak is total garbage. A 96 should get better than that 1 up.
So I ditched the fuel pak,went 106 with t6-6 cams,an S&S breather and a propipe and now my city mileage varies greatly and I measure city riding in smiles per gallon.
And with a pcv I get 50+mpg. Been 12000 miles since I did the swap and I fall in love with my bike every time I start it
Over here our speed limits are lower. Sitting on your 65-70 mph and not riding aggressively, I get around 49mpg cruizing. Stock motor, always have a very clean air filter and Xeid's fitted (14:1 AFR), plus 40 rear 38 front tire pressure, plus stock mufflers with some baffles removed however, if I give it some stick thru the mountains it gulps it down, to around 42mpg. It's all in the wrist...........
