Oil
7 quart's total. You will need 4 quart's of engine oil with filter change. Put in 3 1/2 quart's and check it after warming the engine to operating temp.
The primary takes 38 oz. With the bike sitting level, fill to bottom of clutch basket. Usually takes 38 oz. If you are doing this yourself, Make sure you have the proper Torx socket. It's a #27 Torx.
The Transmission takes 1 quart. Don't use engine oil in the Tranny. Get a good Gear oil like Redline V-twin tranny oil or Amsoil Severe gear.
If you don't have a service manual PM me, I might be able to help.
+1, if you go beyond 3.5 it's going to overfill.....I'm not going to get into flushing the sump like usual or I'm going to end up hijacking the thread and that's not what the OP asked.
