gps and speedo comparison
I took a multi state trip recently with a garmin nuvi 200 i think stuck on my fuel door. The gps showed around 4 to 5 mph slower than my speedometer. Seems like it varied the amount of mph depending on the speed but was always slower. came home and rode with some buddys on a ride and their speedo pretty much matched mine. one rode a yamaha vstar. now this same gps shows true with my trucks mph. wonder whats goin on? The bike is a 09 electraglide standard. stock
I'm currently using a NUVI 255WT. Any GPS I've ever had always read slower mph than the vehicle's speedometer. I was always under the impression that vehicle manufacturer's purposely set them a few mph higher. I've NEVER had a GPS read the same as a spedo. Always a few mph slower.
I trust the GPS mph more than any vehicle's speedometer.
Nothings going on! You are seeing the difference between the vehicle's speedo and external satellite measurement of your speed.
If you were to compare your actual speed with a brand new tyre then with the same tyre almost worn out there will be a difference, as there will be with a different brand of tyre. So a speedo reading can never be very accurate.
In addition speedos themselves are not very accurate by design. Manufacturers are only required to make them accurate to something like zero to +5%.
In other words everything is fine!
