Slightly collapsed tweeter bubble - technique to fix?
Old 08-09-2012 | 01:36 PM
Shakeydeal's Avatar
Shakeydeal
+1 on cosmetics. That is the only thing that is compromised. The sound will be the same. If it bothers you that much, a low vol vacuum cleaner to suck it back out.
Shakey
Old 08-09-2012 | 01:52 PM
Clubber's Avatar
Clubber
Default Verdict
Ok, here's the verdict.
1st Attempt: Straw (bendy). This 1/2 way worked but the dent crossed a grill bar (or a grill bar went right through the middle of the dent). I could lift one side at a time, but the other side would collapse. This was promising, because it did actually make progress.
2nd Attempt: 2 Straws. Took my trusty boot knife and cut the sumbitch in two, one for each side of the grill. This was tricky because I have to pinch each straw to fit in the grill, then lean over with two straws in my mouth to get suction. The tour-pak is detached and on the garage floor, so I have to get on my knees. This is about the time my girlfriend walked in the garage. She asked if I was blowing my tour-pak and I said yes. She chuckled and went about her day. Ultimately 2 straws didn't work, because it requires more dexterity than I could muster bent over on my knees on the garage floor.
3rd Attempt: Duct tape over a nail. I first tried a fancy folded rig it where I had a duct tape like Q-Tip that I could work with one hand while stabilizing myself with the other. Ended up my duct tape Q-Tip wouldn't fit in the grill. I decided to try the simple route, lightly stab the duct tape and hold it on the end of the nail and use my other hand to aim. This finally worked.
I put the duct tape on the dent and pushed gently and held it there for a couple of seconds so it would adhere, then I jerked the nail out of the grill quickly. A couple of locations using this method pulled out the dent.
Yahoo, saved some dough. Duct tape wins again.
Old 08-09-2012 | 03:02 PM
Uncle Larry's Avatar
Uncle Larry
Doesn't Duct Tape fix everything every time?
http://science.discovery.com/top-ten...duct-tape.html
rleetsc
Audio Systems
14
03-15-2017 08:39 AM
clackavosticus
Audio Systems
10-14-2015 06:26 AM
Blues Guy
Audio Systems
08-31-2015 03:15 PM
InvertedB
Audio Systems
09-24-2014 08:53 AM
dagrounds1
Audio Systems
03-26-2014 06:08 AM
Quick Reply: Slightly collapsed tweeter bubble - technique to fix?
