Lost FOB Unknown Security Code
Old 08-07-2012, 10:41 PM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
Most of the security is installed at the dealer. They use the same code on the bikes so that everyone can remember it. Find the original dealer and you may be able to get the code
Old 08-07-2012, 10:44 PM
Timpechos's Avatar
Timpechos
Timpechos is offline
defalt on mine from the factory was 12345
Old 08-07-2012, 11:10 PM
Sparky73's Avatar
Sparky73
Sparky73 is offline
Originally Posted by DvlDogBkr
I lost my only FOB riding to work last week, I didn't realize it until I got ready to go home. I contacted the previous (1st) owner and he couldn't remember the security code. My solution, buy a TSM as opposed to the TSSM. I know I can install thins myself but is there a way for me to flash the computer to make it forget the security system or is this only possible with special Harley tech equipment?
PM sent on your default code. Also, a dealer can reset the code for you.
Old 08-07-2012, 11:18 PM
09UltraRyder's Avatar
09UltraRyder
09UltraRyder is offline
Try then VIN, but add or subtract one digit for the last number
Old 08-08-2012, 12:02 AM
coyote1000's Avatar
coyote1000
coyote1000 is offline
I just set mine and the code on there was 12345.
Old 08-08-2012, 12:13 AM
vzts4q's Avatar
vzts4q
vzts4q is offline
There is no default code it is what ever the dealer that set it up decided they want to use.
Some use the last 5 of the vin my dealer uses their 5 digit dealer code.
My salesman made a VERY big deal out of explaining the importance of changing the code to something other than the one they put in. And also made a specific mention to the fob serial number tags. These have a note on them to place them in the owners manual after the bike is set-up.
And I believe not even the dealer can reset the security unless they have one of the fob serial numbers.
Old 08-08-2012, 04:41 AM
HDCat's Avatar
HDCat
HDCat is offline
Ditto, my 08 UC's factory code was "12345." A HD tech at a local rally hooked it up to his computer and changed it for me for free. Hope this all works out for you!
Old 08-08-2012, 07:16 AM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,923 Likes on 19,371 Posts
https://www.hdforums.com/forum/engin...ml#post7910911
Check out this link ... It might help you! Good Luck Brother.
Old 08-08-2012, 06:06 PM
DvlDogBkr's Avatar
DvlDogBkr
DvlDogBkr is offline
Uncle Larry, thanks brother I will give that a shot, saves me at least $40 and a trip to the stealership if it works!
treyeighty (07-19-2024)
Old 08-08-2012, 06:22 PM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
Call a HD dealer or go there with your reg in hand and they may have it.
Quick Reply: Lost FOB Unknown Security Code
