What gauges would you add?
I have an EG Standard, so I have just the four gauges: Speedo/Tach, Fuel Indicator, and Voltmeter. I have contemplated getting two more gauges for the lower two, but don't really want the air temperature (given that I live in Phoenix, it'll be maxed out most of the time anyways!). What would be the best two to get, and how difficult would they be to install? I was thinking the oil temp and/or oil pressure, would it be better to have both, or just one? Not sure what to pick for the other side, assuming I only picked one of the oil ones, maybe the compass or something.....
RE: What gauges would you add?
I would go with the oil gauges. I already had the oil pressure gauge so I ditched the air temp gauge (which is even useless here in the northeast) and installed the oil temp. Which one do you pick? If it were my decision I would go with the oil pressure. You know that your oil will be hot but I would want to know what my pressure is especially if the motor were to go into the heat management mode. Screw the compass, who cares what direction you're heading, it's the ride not the destination.
The installations are fairly straight forward, but it helps to have a service manual. The oil temp sensor, (If it goes where it was instructed on my installation) can be a MAJOR PAIN IN THE AZZ, but there is a away around that.
Oil gauges. Like you said, the air temp is as usefull as ***** on a bull. The compass?? The sun rises in the east, and sets in the west... you can figure the rest out pretty easily. If you only do one, I agree with soos.. do the oil pressure, but while you have the fairing off, you might as well do the complete job. I think it would look odd to have one blank spot instead of a gauge there.
ORIGINAL: Bryan TTM
if you take out the gauge over the air temp gauge first, its lots easier to install the oil temp gauge
ORIGINAL: chesterbud
Has anyone tried the HD Oil Temp gauges that fit into the dipstick hole? I was wondering if they were of any value or should I just get the proper gauge?
