Tourpak extender
Old 07-03-2006 | 12:14 PM
2k3hog's Avatar
2k3hog
Default RE: Tourpak extender
I have the kit from George Anderson also; $102.00 total. This guy has a quality product that is very easy to install. It comes with all the hardware you'll need and everything fits. I set mine at 2 1/2 inches and the wife loves it. It didn't change the ride or handling at all. He doesn't have a web site, but you can call him at the number rleggs posted.
  #32
Old 04-06-2009 | 04:14 PM
swlamedic's Avatar
swlamedic
Default Thanks a Ton
Originally Posted by soos
Dumb is: NOT asking questions. Now I assume you have an 06 because I believe that is the year that HD offered the adjustable TP. That said, look underneath the TP in the rear and look for the detent. If you see it and it is on the outside of the mounting bracket rail your TP is already adjusted as far back as possible. If the detent is inside the bracket rail then you have room to move it back. The adjustment is about 1" - 1.25". Moving it is easy. Just undo the 5 bolts holding it in place, leaving one bolt still fastened on the high side so the TP doesn't flip off. Hold the TP in place and remove all the bolts including the last one. Move the TP back, set the detent on the bracket rail and reinstall the bolts. Still confused? PM me and I will give you my cell #.
I bought a used UC and was wondering if it was already done or not. NOW, I know what to go home to look for, and decide if I need the kit, or if I have an optional to try first. Thanks for the intel!
  #33
Old 04-06-2009 | 04:28 PM
davep's Avatar
davep
Call George Anderson moline, il for tour pac relocator kit. I installed one on my bike and it's excellence. Phone number 309-762-6291
trigger1911
Audio Systems
03-09-2012 08:10 AM
ldbarchee
Audio Systems
02-22-2011 06:57 AM
Rich13115
12-27-2008 11:58 PM
Sincecrazy
12-03-2008 01:15 PM
rbscooter
10-13-2008 11:17 PM
Quick Reply: Tourpak extender
