Bushtec hitch '10 Ultra Classic
Posted this on the general as weel, but, might be better here. Just finished up a Bushtec hitch on my 2010 Ultra Classic and it sure doesn't look right. Pin on the tow bar sits about 15 degrees from vertical and the bushing in the Hein joint is also at an angle. Does anybody else's sit like this?
I had a bushtec hitch on my 07 ultra and it did not look like the pic you posted. The sales person at bustec told me that I could not use the receiver from the 07 because the version II was at a different angle. Wondering if maybe they sent you the reciever from the 07 style kit?
I commented on your post in the other section, prior to seeing your picture.
I share your opinion that I would not tow with that set up. Like I mentioned before, its a life or death situation and that hitch better be good, solid and reliable.
I would start to look around at different vendors as the hitch you have looks like a disaster waiting to happen.
If you do not load that trailer correctly and weight distribution be incorrect that hitch may send you into a bad wobble that you may not recover from.
I wish you the best with this but as a member who trailers as well, I would remove it, never hitch it up and go onto the street.
Best of luck with it.
