tw5 or tw6 cams?
RE: tw5 or tw6 cams?
I had your exact same setup on my 03 Fatboy with Woods TW5-G cams. I liked them. They were torque monsters to be sure. They weren't excessively loud as some Woods cams tend to be. I admit to liking the gear whine sound though. It doesn't seem to bother most however. I was getting 104 ft/lb and 101 HP with your setup and a carbed bike. About 88ft/lb was between 1800-2200 RPM...could low end torque cam. That said, I thought I'd never go with HD cams, but have the SE 203's on my 95" Flattops and stock heads Street Glide, and even though the dyno give's me 78 and 86, for some reason, I enjoy the bike better and like the feel of the cams. The TW5's could be a little peaky.
ORIGINAL: Harleypaw
TW6G is a really good low end torque cam for stock heads, it does run out a little early. TW5G will give you more on the low end and holds up pretty good on top, the 5 does require SE heads as it's a higher lift cam.
nogood o~`o
HarleyPaw, You are correct on the lift numbers, I ran the TW5G's in my 95" and made really good numbers, HP 102 and TQ 115. You are also correct in that the 5's need the HTCC heads to handle the lift. Would not hesitate to run them again.
No experience with the 6's though, but a buddy runs em and has no complaints
Received 7,822 Likes
The biggest improvment you could do would be to get rid of those heads. They have to large of ports for most applications and actually hurt performance. I had them on my motor and got rid of them and gained power. As far as cams go I am not familar with the Woods grinds.
