Front fork reflector removal
08-06-2012, 02:31 PM
How difficult is it to remove these reflectors? I replaced the turn sig + front fender lite with smoke lenses, made a HUGE difference. Now, the front fork reflector stick out like a fart in an oxygen tent. Heat gun + dental floss? Don't want a mess on the fork that won't clean up. THANX!
08-06-2012, 02:34 PM
I just used a putty knife to get under the edge of it and pulled... then wiped the sticky residue with alcohol on a rag
08-06-2012, 02:35 PM
dental floss will work, get as close to the fork as possible. 3M adhesive remover will take care of the rest
08-06-2012, 02:49 PM
Quote:
Originally Posted by
ss55539
This, or fishing line.
08-06-2012, 03:30 PM
08-06-2012, 03:34 PM
Use a hair blow-dryer, in conjunction with dental floss or mono fishing line.
Clean off residue with WD-40.
08-06-2012, 03:38 PM
Fishing line and Goo B Gone for the residual glue. works like a charm.
08-06-2012, 06:52 PM
Just get under the edge and pull 'till they come off. Then use "Goo Gone" to clean off the residual glue. I've removed 6 reflectors and 2 tank emblems so far this year with no problem.
08-06-2012, 06:56 PM
yep I just pulled mine off,cleaned off the adhesive with some wd -40
08-06-2012, 09:36 PM
