FLHP Fender Rail Mod: Just Rubber Removal
did a search and found tons of guys removing fender rails from SG and others but not exactly what I am looking for. I just want to remove the rubber that is between the chrome fender rail and the additional chrome trim that hangs below the fender. It looks like you have to unbolt a strap (3 bolts) that goes on the inside of the fender right in the very front that holds the fender and each piece of chrome trim in alignment, then remnove 2 small bolts from the inside out that hold the rubber to the chrome trim on each side of the fender. My concern is that without the rubber and strap the chrome trim wont have any support in the front of fender and will bounce around or sag.
The look I am going for is sort of what you see on a Delux
http://media.photobucket.com/image/r...e/HPIM1257.jpg
You cant really tell whats holding the front of the rail up if anything.
Anyone done this?
Anyone done this?
