Cable Lashing Procedure
trying to do the procedure on my 06 ultra and can't get a green light on the cruise when I start the bike. I am suspecting a bad roll off switch on the throttle cable, but trying to do the lash as the manual describes. Can it be done it you have a bad roll off switch?
Yes the green will show during testing and initialization procedures but normal operating you would be correct.
I am doing the cable lash procedure as described in the manual. You start by pushing the resume/set to resume, turn cruise switch on, key switch to ignition and the red cruise light turns green, then let off the resume and light goes back red, then hit resume again and the engine will rev setting the memory of the motor revs. This is from memory but I think I am close.
I can't get the green light, wondering about the roll off switch.
06 ultra
06 ultra
See if this is any help, click on the link below
https://www.hdforums.com/forum/engin...and-codes.html
gobblerhuntr...I assume your cruise is not engaging. If so, I had that happen on my 06 RKC. what turned out to be the problem is that when my bike was serviced, the tech took the right side Kury neck cover off and when he reinstalled it, he put the cables in a bind. none of the testing showed the problem and I only discovered the problem when I took the cover off, saw the cables routed incorrectly.
oh well, just a thought if you have a similar setup as I was thinking switch and it was not.
