No neutral light when hot ?
easy enough to unscrew the neutral switch and test it.
it is possible that when you do this, you will find a bad wire connection- or just removing and re-seating the wiring will be the fix.
hot makes for more resistance in electrical circuits.
btw the Speedo sensor is the one held in with an allen screw, the neutral switch is further inboard and screws into the top of the tranny
mike
mike
