Weird metallic noise, front exhaust pipe area.
Got this weird noise coming from somewhere around the area of where the front exhaust pipe attaches to the exhaust port. Heard it for the last month or so. Doesn't sound like anything serious, just annoying.
Not sure exactly where it's coming from, it's a metallic sound. Kinda sounds like metal expanding/contracting from heat. Kinda sounds like when you shut off the bike and you can hear metallic sounds as the metal cools, except, I can hear it while I'm riding the bike.
Seems to be worse on hot days. I thought maybe one of the clamps for the heat shields had broken or come loose, but I checked and they're ok.
Seems to be worse after coming to a stop for a stop sign or traffic light and then taking off again.
Anyone else hearing something like this?
Almost sounds like I dropped a screw in the front exhaust pipe and it rattles around once in a while?
It does sound like metal expanding/contracting from heat, but I never used to hear it, only the last month or so. And I shouldn't hear it while riding, just after shutting the bike down.
Only thing I can think of, is that we've had weather that is hotter than normal lately, maybe it's just the increased heat?
I think what you are hearing is the slightest of 'ping'. The ignition computer is advancing the ignition timing to the maximum for the conditions (altitude, temp, load).
It has also been described like pebbles off the tire inside the fender.
Continue to use premium fuel, no harm being done.
Thanks, your "pebbles off the tire inside the fender" sounds exactly like it.
Guess that would explain why I've been hearing it more lately with the hotter weather we've had in the midwest?
I do use Premium Fuel from Mobil, I think it's 93 octane.
I'm coming up on 1k mile service will have dealer check it out, i think its the heat shield also but i plan to switch out the stock exhaust so hopefully it goes away then.
This is totally a guess but you might check the rubber hangers for the mufflers and the muffler clamps. The muffler clamp can let the mufflers move rearward until they kind of jam up on the rubber hangers. Then the exhaust system is no longer free to move and it puts a strain on the header connection. Like I said a guess.
You could also completely loosen the worm drive clamps for the heat shields and kind of move things slightly and then retighten. My bike made a funny sound from that area and it was the heat shields or clamps.
Same thing here on my '12 FXDC. I know the pinging from the engine cooling down when off is normal, but hearing it while riding had me saying "WTF?!" The heat shields/clamps expanding and contracting while running is a probable explanation. My 1k service is coming up so I'll see what the shop says when I take it in. I'm glad I found this post before I went nuts.
